new member
johnee s
new member
Post by johnee s »
great to be part of the forum, having visited plenty times as a guest
over in sweden i bought a small farm with most of the land kept by a previous previous owner, and seperately negotiated a veteran tractor from the previous owners clutches, he had 3. Have to say l absolutely love the machine, where ride on mowers cost a pretty penny i think this was a bargain
i believe a 1952 fordson major,with a replacement engine,fl cylinder head, raised pto, welded and bolted on roll cage cab type thing removed. Its my first tractor, a steep learning curve.
Came with a snow plough and have since secured a arkiv sickle mower which seems to keep the field grass down fine. so will be used and maintained for light work and stored in the barn.
has a list of requirements which will chip away at, as i learn
52 major s/n 1226890
engine s619226
Re: new member
Welcome John,
You are going to enjoye your tractor. Looks great.
johnee s
Re: new member
Post by johnee s »
hi Henk
thanks for the welcome.
have a lot to learn but sure glad i have the fordson
engine s619226
Mervyn Spencer
Re: new member
Post by Mervyn Spencer »
Wow what a beautiful tractor I hope you have lots fun using it.
johnee s
Re: new member
Post by johnee s »
Hi Mervin,
Thanks for the reply. Fun for sure experience using it will come.
It’s had about 4 hrs continuous use in the field and 1 oil leak hopefully fixed.
Will find out next time I cut the field
engine s619226
Re: new member
Post by Dandy Dave »
She looks like a good one! Keep her well maintained and treat her like you would your Grandmother. You will get many enjoyable hours out of the work she will do. Dandy Dave!
johnee s
Re: new member
Post by johnee s »
Thanks Dave,
With the support of the forum, I will do my best
engine s619226
