Disc brakes
Disc brakes
Hi folks, this is my first post in the forum, already had a good read through and learned an awful lot. I’ve recently bought my first Fordson major and started going through it to sort some of the issues. I’ve started to strip the brakes today and have come across a problem with removing the inner disc. Outer disc and actuator came off easily but I can’t see how the inner disc comes off, failing light tonight has meant that I’ve abandoned it for now and was hoping someone has got some tips for me. Thanks in advance
Re: Disc brakes
Hello Tim,
It should come off like the first disc, but things can get a bit rusty over the years. Put some wd40 on the spline and see if you can move it a bit.
