Dexta missing live pto front thrust washer
FarmallM51
1960 Dexta with live pto doesn't have the thrust washer that sits between the drive gear and front bearing. It's part # C7NN-B777-A in the parts manual. What can I use to replace this part? Anyone have the dimensions that I can take to a machine shop? Thanks.
Re: Dexta missing live pto front thrust washer
Try this
Number subs to C7NNB777B, appears to be still available from Case New Holland, about $30.
Dimensions shown are: 26.67mm ID x 30.96mm OD x 4.83mm Thick. (A little over .019" thick.)
