reluctant starter
AlexB
reluctant starter
Post by AlexB »
My superdexta has become a reluctant starter, in that when I press the starter lever, there are clicks but no action.
Moving the L/H lever has tended to prompt action but could well be co-incidence or a pointer to something else
Any ideas please?
I have searched on previous posts but not found anything specific.
Re: reluctant starter
Before getting too deep into component faults check all the heavy cable connections, dismantling and cleaning if necessary. This applies to live and earth.
MikesDexta
Post by MikesDexta »
check the battery voltage
try bypassing the solenoid, if it works it's either the solenoid (always the case when I've had clicking) or a bad connection
check cable continuity battery to solenoid and solenoid to battery using a multimeter
good luck
Mike
1959 Dexta
