length x width x depth and cca ah ect
battery size
battery size
needing a new battery for the dexta does any one know the size to fit battery tray
Les bryant
Re: battery size
I use NS 70 in my super dexta . Cheers Les
Re: battery size
thanks les but doesnt really help.
need sizes
need sizes
Re: battery size
Mervyn Spencer
Re: battery size
Hi Guys, it would be interesting to see a diagram of the battery clamp you will be using please.
Mervyn.
Mervyn.
Re: battery size
Sky Blue,
The battery I have fitted in my Dexta is a Yuasa YBX3000, 90Ah, 700Amps. The dimensions are as follows 8 inch high by 63/4 inch deep by 12 inch wide. Fits perfect and the bonnet closes no problem. Plenty of power to start as well. I made a battery clamp from small angle to suit and retainers made from M6 threaded rod. Flattened one end of the rod to fit in the slot in front of the fuel tank. Took notches out the corners to make sue the battery terminals had clearance. See attached photos of set up. If you need the sizes of the retainer frame I made let me know.
Photo of battery and clamp.
Photo of front clamp retainer.
Photo of rear clamp retainer.
Photo of side view of retainer.
Hope this info is of some use.
Charlie.
Charlie.
Re: battery size
thanks guys just what i needed
Mervyn Spencer
Re: battery size
Thank you Charlie, my tractor been a Super Dexta, the fire wall is narrow I'm sure you know what I am referring too. I must have a look and see if I can adapt your clamp style to fit my batt. Take care Mervyn.
