oil leak
Brian Cox
oil leak
Post by Brian Cox »
Help! Due to ill health tractor not moved for nine months. Now started once again and there is a bad oil leak at the services it is just above the end of the qualtroll lever, it's the opening with the pin in it. Never done this kind of thing before, can anyone help with advice?
Brian Cox
Re: oil leak
Post by Brian Cox »
just found out, it's where the flow control valve is housed
Brian Cox
Re: oil leak
Post by Brian Cox »
I see it's the same problem as Terry 274 , hopefully the answer will come up on his or my site :cry:
Re: oil leak
Brian I suggest to discuss this further on in the the other thread started by Terry
Brian Cox
Re: oil leak
Post by Brian Cox »
Thanks Mathias, however this is the first time my tractor has moved in nine months and I am desperate for some fun :buddies:
Brian Cox
Re: oil leak
Post by Brian Cox »
unit off soaking in release oil ,waiting on seals and gasket coming :)
