WANTED flow control assembly - 1963 NSM
JGLea
Post by JGLea »
After the assembly (including linkage) for a new performance super major 1963. For some reason this is missing on a recently purchased machine. The remains of the end of the linkage i.e. the spring loaded lever next to the main control lever are there... however the rest including the flow control knob is missing.
If anyone is breaking one and/or has one available please let me know.
Many thanks
Josh.
Re: WANTED flow control assembly - 1963 NSM
Do you have a DAR valve? If so the flow control doesn't fit that, so you'll need to change it for the auxiliary service valve if you want the flow control valve.
