Registration
wisey75080
Registration
Post by wisey75080 »
Hi there
Can anyone inform me how i go about registering my fordson E27N?
It has never been registered before, so i am after an age related one.
What do i need form my tractor to proceed, and is there someone i can go to to assist me?
Cheers Dave
Re: Registration
You need the serial number and all the casting codes, others here will give you a better idea of what you need to do with the DVLA.
wisey75080
Re: Registration
I'll see what numbers I can find.
Thank you Sandy.
Re: Registration
Your serial number should be above no 1 inlet port or on the flange between engine and gearbox, engine side on the right hand side.
This serial no gives a clue about the age of your tractor. Ideally the casting codes on all greater parts are of around the same date. Although many fordsons have been Frankensteined in the past,.....
Rgds emiel.
