Anybody out there how know how to remove the return filter on my Super Major-62.
I have removed the hydraulic top cover It look like I have to remove it from below ?
Thankk/Per
						hydralic oil return filter
Re: hydralic oil return filter
You'll need to remove the feed pipe from the pump, then lower both the feed and drain pipes carefully, remove the back pressure valve and remove the filter noting all seals and washers; you won't need to drain the oil for this as it can be done from above.
