Parts for power steering and Hydraulic Valve Adapter Kit
Kjetil
Post by Kjetil »
Anyone know parts from www.steinertractor.com
For the Super Major they have:
Eaton Power Steering Pump Seal and O-Ring Kit
Anyone knows what Eaton Power Steering is?
Does it fit the OEM Fordson Super Major power steering?
Power Steering Pump Filter
Hydraulic Valve Adapter Kit includes o-rings and instructions.
What is this?
They also have a Neutral Safety Switch which is also unknown to me
Since we are talking about Power steering.
Anyone knows were to buy gasket kit for the ram?
Any help welcome
Thanks, Kjetil
Re: Parts for power steering and Hydraulic Valve Adapter Kit
The neutral switch they offer is actually the starter switch that operates the solenoid. The seal and o-ring kit I don't know about but the filter looks ok. As for the hydraulic valve adaptor kit I think it's for a spool valve.
The original filter is a Baldwin P183 or similar one from another supplier. Use this site to find your brand: https://www.oilfilter-crossreference.com/
I haven't found a O-ring kit for the power steering. I found the pump to be an easy fix, but the ram has started leaking again here.
You have one oil-seal in the pump and about 7 o-rings.
From the manual and/or CNH website:
2x E113ld9 between reservoir and pump
1x e217ld9 (seal)
1x87146s94 2.563'' ID x .103' (inside the pump)
1x 9672467 .562'' ID x .103' (inside the pump)
1x 87050s94 .812" ID x .139" one of the feed pipes
1x116022es 1" id x1.16" od x 0.06" flat washer one of the feed pipes
1xe111ld9 (reservoir cover)
I guess the size of the seal was: 1.125"x0.688"x0.313"
