which flasher unit for 3 x 21watt plus warning ?
AlexB
Post by AlexB »
Hi all
I am struggling to find a positive earth flasher unit which is big enough to run a trailer board
Any suggestions please?
thanks
Re: which flasher unit for 3 x 21watt plus warning ?
With negative earth it’s easier. Seems for positive earth a caravan relay may help you.
https://www.autoelectricsupplies.co.uk/ ... ategory/35
You could always get a negative earth flasher, fitting it completely isolated from the vehicle, allowing it to be on a positive earth vehicle.
AlexB
Post by AlexB »
thanks for the suggestions
Some Lucas are both polarities - the one on my positive earth landrover is, but it is only 47 watts
I'll keep looking
many thanks
