Fordson Super Dexta starter bolt?
IlkkaV
Post by IlkkaV »
Hello all!
I made quite a huge repair on my Super Dexta. Now I'm in trouble because I lost one bolt which will attach starter. There is two bolts with nuts, but third one is missing. This missing bolt is different, because there is thread in the adapter plate. So only bolt is missing. I tried to found the bolt dimensions but did not found it? Do anyone have ideas what might be the correct bolt dimensions? Photo can be found on: https://ibb.co/LYZCTfz
Re: Fordson Super Dexta starter bolt?
I think its the same thread as the other ones, but I'm not sure about the length, try looking at a Dexta parts book.
Can’t find exact specs in parts book unfortunately. The diameter is 3/8, so a 3/8-24 UNC of correct length will fit. Do take the right length. A too long gives issues with flywheel. To short might strip out thread in plate between engine and clutch housing.
Rgds
Too long a bolt will hit the flywheel, I think it should be about 1" long but I'm not sure.
Mervyn Spencer
Post by Mervyn Spencer »
Hi, the bolt in question in metric is about 31.4mm long, about 9.4mm dia. sorry about the mm. my vernia is only calibrated in mm.
Mervyn.
Mervyn Spencer
Mervyn Spencer
This is the bolt you are looking at.
mERVYN.
1 1/4" long and 3/8" in diameter.
