Injector leak off pipe copper washers
1045mark
Post by 1045mark »
I am looking for the copper washers that fit onto the injectors for the leak off pipe.
Am I right in thinking they are 5/16" in size? I don't have the tractor here and was hoping to get some today.
Many thanks.
Mark.
Re: Injector leak off pipe copper washers
There are no copper washers on the injector banjo's for the leak off line, the only washers are on the banjo on the cylinder head just below the rocker cover. Those ones are 1/4" in diameter.
1045mark
Post by 1045mark »
Hi Sandy,
Thanks for the reply.
Ok that's great that will be the reason there aren't any on mine then. Will make a note of the other washer size in case I need that instead.
Many thanks.
Mark.
