Fuel pump doesn’t seem to fit
62Super
Post by 62Super »
Has anyone had trouble getting pump to bolt up to
The bracket on the engine. I’m trying to bolt a new one
Up but the bolt holes are about 1/2 inch out . Not
Sure if I need to cut some out of the coupler or what
I need to do
Re: Fuel pump doesn’t seem to fit
Try loosening the clamp bolt, you should get it on doing that. A pic would help too.
As Sandy says, loosen the bolt on the coupler that is attatched to the engine and gently tap it forward until it's moved far enough to allow the holes to line up on the pump bracket. Fit the pump and if the coupler is too far forward gently tap it back to close up the gap and retighten the clamp bolt on the coupler, but don't hit it hard, just small taps
62Super
Post by 62Super »
The bolt only allows the coupler to move to the end of
The grove in the auxiliary shaft. The coupler itself
Is slightly longer on the pump that I’m replacing. Wondering if I should try and switch couplers or if they
Will be slightly different as well.
The couplers should be the same length, have you still got the old pump with the coupler on it?
Is it a vacuum type pump or one with a mechanical governor?
The auxiliary shaft for the minimec is slightly longer.
Just to clarify, the couplers should be the same length fron the flange to the front of the locating pegs, not overall length. The pump coupler should be 46mm long
