Narrow Dexta badge
Narrow Dexta badge
After looking around for other Narrow Dexta's, I saw some with a badge saying Narrow either on the LH grill middle or the LH side of the bonnet. Davie has holes on the LH side of the bonnet 2 1/4" apart and 3/16" in diameter at about the level of the bonnet handles just next to the battery. Do you think this is where this badge would have been? (pic available if needed)
Mervyn Spencer
Re: Narrow Dexta badge
Post by Mervyn Spencer »
Hi Sandy, If I read you correctly the holes on the side of the bonnet are for the Fordson Badge that were orniments of the Super Dexta :scratchhead: .
No, the Super Dexta ones would be in place of the restyled Dexta badges (Davie is a Narrow Dexta), between the bonnet handles and above the level of the prop. These holes on Davie are only on the LH side and next to the battery.
Just found another Narrow Dexta (Bob Cullen's one, very visible here: viewtopic.php?f=3&t=7793) that does have the badge in the area where Davie has holes.
Mervyn Spencer
Okay now I see, to be honest I have never had the privaledge of seeing a Narrow Dexta. I hope you will find one soon, I would imagine they are like hens teeth to find.
Mervyn.
I think the badge is the rare part, Narrow Dexta's outnumber std. width Dexta's here, but most are much more modified than Davie is. It makes the badge a rarer part.
