Dealership
Dexta1961
Dealership
Post by Dexta1961 »
Hi, i would like to know if there are any ways of finding out the dealership your fordson dexta was sold from
If there is here is the serial numbers of mine:
Below starter on sump:0830225T214J8
Above brake pedals:957ET3C1SF
Clutch housing:957E77809
Beside oil filter:2GKHI372
Left half axle:957E4013T4
(If there are more they aren't readable)
Re: Dealership
Hi, is it a UK dexta, and if so do you have a registration number?
Re: Dealership
The quick answer is no, but with casting codes and the engine number we can confirm that your Dexta is a late 1961 as the serial number suggests (if it's from the LH side of the bell housing flange). Most of the things you've posted are part numbers. Some tractors have a dealer plate on the bonnet, but not all, and many will have been lost. If you have a number plate see if you can find information with it, you might be lucky.
Dexta1961
Re: Dealership
Post by Dexta1961 »
Billy26f5,
There is a dealership badge on my bonnet but i don't know if its the original bonnet
*i just mentioned any number i could see to be sure
Re: Dealership
That might be enough, if you can find the records from the dealership you might be lucky and find your Dexta. If you don't find it your bonnet is not original.
