Battery, generator and polarisation
Rijono
Post by Rijono »
So I have just finished a small restoration of my Fordson Major Diesel 1953 and have replaced the battery, starter, wiring loom, generator, voltage regulator, etc.
Can you advise me please if I have to flash the voltage regulator. If so can someone please tell me the process.
I have just fitted headlights so need to know I’m replacing what is being consumed by the lamps.
Thank you
Re: Battery, generator and polarisation
The headlights are 35W each in theory. You will have to polarise the dynamo, remember it's a positive earth system.
