Correct size towing trailer
Jimbratt
Post by Jimbratt »
Guys
I’m looking for the best type of trailer to move my Super Major around with
Most car trailers are to long
What about a plant trailer
Any body got any suggestions or maybe has something for sale
My towing vehicle is a Ford Ranger 3lt so no issues on towing weights
Jim
Re: Correct size towing trailer
Hi Jim, the only problem with using a plant trailer, so i've been told, is that a tractor is usually heavier on the back end, and as a plant trailer is shorter than a car trailer you can't move the tractor back ar forward to get the weight distribution correct
Jimbratt
Post by Jimbratt »
Thanks John
I think I will stick with a car trailer for that reason
Cheers Jim
