What is my Tractor model ?
FredC
Post by FredC »
Ive been doing a lot of research online but still cannot identify what is my tractor model.
My suspicion is that it is a 1964 Fordson Tractor Gas (Petrol), but I cannot confirm.
Here is a link from YT : https://youtu.be/bAmJU8e5Dy4
My tractor is pretty much identical except for the Control Panel which as been customized.
Furthermore, I took some pictures of what I think is the serial number and other numbers.
Some pictures show a logo that seems to show the word EnFo
Can anyone identify this logo and its meaning ?
What is the serial number ?
Here are my pictures of the serial number and Logo : https://postimg.cc/gallery/TD4njQ2
Here are my pictures of the actual Tractor : https://postimg.cc/gallery/6wNrT3X
thanks for your help
Life's too short to be waiting for the end of the world.
Re: What is my Tractor model ?
You have a Fordson Dexta tractor with a petrol engine, as it is called in British English.
There are not many around of them.
EnFo is the mark Ford of England casted into many parts. Later products had FoMoCo in the oval. The cast in 957E code is a mould code, not a part no. The other code indicates a casting date.
The serial number should be stamped in on the clutch housing, near the starter or on the opposite side and should start with 959E……..I believe
I don’t believe you’ve a 64 model but do not have the documents at hand to determine the dates of the casting codes. I’m sure billy26f5 can help you out on the casting codes and many more useful details.
I have moved this topic to the Dexta forum. Please continu writing there.
The gearbox does seem to be a 64, 12 March casting. Look for other casting codes on most castings except the engine, find the serial number on the front LH bell housing flange just in front of the flywheel inspection cover.
Emiel wrote:
Mon Oct 11, 2021 6:04 pm
957E is the Ford code for a Dexta, 959E a petrol Dexta and 960E a Super Dexta. 957E-7005 is the gearbox casting part number.
Only before November 61, from then on the prefix is 09 and a letter, in your case it's probably 09D (assuming yours is 64), but I'm not sure as I can't see the numbers. You also need the engine number, prefixed FPL27. Your firewall is much earlier.
FredC
Post by FredC »
You guys are awesome. Didn't expect such a quick and efficient answer. Thanks ! :)
Now I have to find the proper manuals. I've gotten my hand on some pdf from the web but they are no the specific manuals for my Gasoline Dexta.
And I will now identify the serial number with the info you provided.
Back soon with more questions.
Cheers :beer:
The only thing you'll find easily for the petrol Dexta is the instruction book supplement, all other things are very rare.
