Sump strainer gasket
Bounce
Post by Bounce »
Has anyone had difficulty getting their sump strainer gasket to seal?
I’m on my third attempt, I’ve put it together dry, I’ve put it together with hylomar, and last attempt I’ve tried it with a smear of grease, with a new gasket each time but every time it starts to leak after a few days. Any suggestions?
Re: Sump strainer gasket
Look for a scrape in the surfaces, you could also try other sealing methods. Ensure you fit it tight enough.
Bluebilly
Post by Bluebilly »
I normally use Permatex no2 the non hardening one. It has never failed my yet on any of my restorations.
Grey Fergie
Ford 2000 - Pre-force
1958 Dexta
Roadless 75
MF35 Industrial
MF135 Industrial
MF135 multipower
MF 165
MF 240
MF 360
MF 20E - Industrial
MF 20B - Industrial
MF 20B - Industrial with 7 gang mower
SAME Solar 60
Bounce
Post by Bounce »
Do you use the permatex no2 on its own or smeared onto the gasket?
Bluebilly
Post by Bluebilly »
Depends on the scenario. If I think the surface is good enough its good on its own, otherwise a smear on the gasket never does any harm in my opinion
Grey Fergie
1958 Dexta
Roadless 75
MF35 Industrial
MF135 Industrial
MF135 multipower
MF 165
MF 240
MF 360
MF 20E - Industrial
MF 20B - Industrial
SAME Solar 60
