55 injector timing
55 injector timing
When I first checked timing on Hyacinth with the timing mark on flywheel at 26 the marks on the injector pump/timing plate were off by 1/8" or so. I thought I was out of adjustment, but realized yesterday I had looked at it the wrong way and now have it exactly aligned. While she started and ran good before, I feel like she gained on cold start time( Faster). Also, maybe less of that slobber out exhaust. While I understand hard work is one of the best remedies for this there will be no plowing for quite some time. Pulling logs does not even seem like much work as ground conditions are just right for it. Frozen ground with a light snow on top.
One question regarding the timing adjustment I have is now it seems a bit louder near injector, especially at low idle.
Clears up at faster idle, not just muffled by engine noise. Cap screws are tight.
Re: 55 injector timing
The coupling is always noisy, and you will notice it more when idling.
Thanks Sandy. I know they are noisy, I enjoy it. Maybe I was imagining it was louder/different.
Would you expect much difference in starting and running in general with such a small adjustment?
Somewhat related question: I have no reason to suspect governor diaphragm is compromised other than an assumption it is very old. I have a new one, but not sure if I should bother changing it. Idle and throttle response are both good.
Personally i wouldn't bother touching it if all is good, they will last years. When it does need changing Hyacinth will certainly let you know, the revs will be all over the place!
Thanks John, I'll keep it in the spares box!
John b wrote:
Mon Jan 24, 2022 7:09 pm
Agree 100% John, you'll most probably find the revs run away no matter how low the throttle is.
As far as the timing goes you should notice more power and better starting, but if you were in the narrow margin where the engine will run ok you probably won't notice it much.
Thank you Sandy.
What wears that makes timing adjustment necessary?
The drive pad in the coupling will eventually, although you might find that the claw bolts have allowed the flange to move and upset the timing, always make sure they're tight.
SvendH
Post by SvendH »
The pump internals will wear/go out of ajustment over time😉
For more info om this subject se Shepps great writeups on it.
The drive pad will wear far quicker on a well kept engine as the pump will be properly lubricated.
