1960 diesel fuel filter washers
FarmallM51
Post by FarmallM51 »
I'm replacing the diesel fuel filter and didn't notice the location of washers when the filter came out. There is a flat metal washer 1.25" in diameter with a hole large enough to go over the center post in the filter housing and a smaller fiber washer with the same diameter center hole. Do these go on top or bottom of the filter? It would appear that if they go on top that would impede fuel flow to the output port. Thanks.
Marlin
Re: 1960 diesel fuel filter washers
I think it's the bottom seal, look in a parts book to be sure though.
http://www.smallholderservices.co.uk/si ... s_list.pdf page 104
FarmallM51
Thanks, you're right. Now I have to find that darn spring.
Marlin
