removal of cast wheels
am333rcr
Post by am333rcr »
hi
new to the forum have been watching for a while.
so i have fordson with the 4 spoke cast wheels.
i want to put ti wheels on it
so can i just put new hubs on or will the stub axle be required aswell?
thanks in advance
Re: removal of cast wheels
Only the hubs abs bearings should be changed. Stub axle is the same. Bearings are same dimensions as well.
am333rcr
Post by am333rcr »
hi
thats what i thought. i can get the whole axle if required
cheers
alistair
If you want pressed wheels you must fit weights, as you'll lose front end weight essential for pulling heavy loads. Otherwise just as Emiel says.
