4600 piston question
In the process of rebuilding a 4600 engine and the new pistons won't fit. Ok, take it as read that we got the wrong ones. Question is, they fit the bore perfectly, but at TDC the crown is 2+ mm above the block face so what would they be for? I believe the difference between a 41 and 46 engine is the bore, the stroke being identical- or have I got that wrong? The block on this tractor has 'T7' cast into the lh side of it.
Any advice please???
If it works, leave it alone.
Re: 4600 piston question
You are correct about the bore and stroke and my 4100 block has T7stamped on the l/h side so i think that's just the casting stamp. I think the 5000 has the same size bore but an extra cylinder, not sure if the pistons are different though
Thanks John. We'll have to take one out and give it a measure from crown to wrist pin and see where we go next. Crank and con rods are original so it can only be the pistons somehow.
Well 4.4 inch bore pistons were used in the Pre force and Force 4000 and 4600 tractors with a 4.4 inch stroke crankshaft. However a 4.4 inch bore piston was also used in the 5000 Force and earlier 6600 tractors and also special 4.4 inch pistons in the 7000 turbocharged engine all with a 4.2 inch stroke crankshaft. That might be where your problem lies.
When the 6600 "Power Plus" engine was introduced around 1978 the crankshaft was changed to a 4.4 inch stroke and the 4.4 inch bore pistons used in that engine then were probably the same as the ones used in the 4600 (and 4000) engine. The 7600 turbo engine also went onto 4.4 inch stroke but the 4.4 inch pistons were specials for the turbo engine. You might have the pistons meant for the 5000 Force and early 6600 engines with the 4.2 inch stroke crankshaft. Ford claimed in their advertising that con rods were a standard size and interchangeable for all normally aspirated engines, so if that is the case there must be 2 different types of 4.4 inch bore pistons, one type for the 4.4 inch crankshaft stroke engines and one for the 4.2 inch stroke crankshaft engines. You might have mistakenly bought the ones for the 4.2 inch stroke engine instead of the ones for the 4.4 inch stroke engine which are the right ones for the 4600. In fact I am virtually certain this is what the issue is, you have the pistons for the Force 5000 and early 6600 engines.
Incidentally there will also be 2 types of 4.2 inch bore pistons. The 3000 Pre-Force, the 3000 Force, and the 5000 Pre-Force all had a 4.2 inch bore piston with a 4.2 inch stroke crankshaft. However the 2000 Pre-Force and 2000 Force had a 4.2 inch bore piston with a 3.8 inch stroke crankshaft.
Nice one!
I was aware of the bore difference in some but I just could not find any reference to a stroke issue which is what this clearly is.
It's a friends machine and I've not been back to it recently but when I do I'll let you know how we get on.
Thanks.
The distance between the centre line of the gudgeon pin and the top of the piston crown is one tenth of an inch greater on the 4.4 inch bore pistons used in the Force 5000 and early 6600 engines (which had a 4.2 inch stroke crankshaft) than it is on the 4.4 inch bore pistons used in the Pre Force and Force 4000 and 4600 and 6600 Power Plus engines (all of which had a 4.4 inch stroke crankshaft). One tenth of an inch is about 2.5 mm which is what you say your pistons are proud of the block by.
