Bonnet for Super Dexta 1964
GMJH1965
Post by GMJH1965 »
I have come to a full stop on restoring this tractor as it came with 1/2 a Super D bonnet, air cleaner side and the other half was a Dexta bonnet! I ended up buying a repro bonnet from E bay, big mistake as did not fit!! I then bought a Dexta bonnnet from an Auction site who advertised the bonnet as a Super Dexta, only when it arrived was I able to make out that somebody had just cut off the side wings of a Dexta bonnet!
So I now have a complete Dexta bonnet, an off skew repro Super Dexta bonnet, but no bonnet to finish my Super Dexta.
Any help or advice would be appreciated!!
Many Thanks
Gavin
Re: Bonnet for Super Dexta 1964
All I can suggest is Ebay or auctions, I suggest you clean up the Dexta bonnet and use it in the meantime, see if you can find the correct LH half as then you keep the RH half you had.
GMJH1965
Post by GMJH1965 »
Thanks for that, I be had people picking through but nothing found so far!!
