drag link rubber dimensions
peter2
Post by peter2 »
does anyone know the dimensions for the front rubber sealing of the drag link? Mine has a hole and needs replacement.
I measured 22mm on the smaller end on the pin and about 28 on the outside, and 43mm on the outside of the bigger end, so I assume about 38mm inner diameter of the big end. And I forgot to take the length. :?
Are both ends of the drag link the same. From the agriline website it seems so ...
Peter
1963 Super Major
Re: drag link rubber dimensions
Do you have the sealed drag link or the adjustable one? I can't really help you with the sealed type as we don't have one, on the adjustable one there's a rectangular piece of felt clipped on with a bracket.
peter2
Post by peter2 »
Hi Sandy,
it's the sealed drag link at my Super.
Peter
1963 Super Major
I think the ends are the same on the sealed one (they aren't quite on the adjustable one), you could see if Agriline can provide you with some sizes or even rubbers even if they don't list them.
