Hello everybody,
where to source camshaft bearings for thames trader 6D / ford 590E engine?
What is (was) the original part number?
thanks,
Sjors
camshaft bearings Ford 590E
Re: camshaft bearings Ford 590E
Check enginefixuk and emmark, they might have it. I got mine for the industrial ford engine there
I think you'll probably have to make them, but Mathias has a good starting point.The part numbers are 508E-6261 for the front one and 508E-6262 for the other ones. There are two suffixes, E means std ID and OD, F means std ID 0.020" OD O/S. I think there might be more but I can't find anything.
Thank you all.
