fordson major diesel E1A electrical diagram
glibo
Post by glibo »
Hello
I am looking for an electrical diagram for a Fordson Major Diesel E1a (dynamo) , because I am assembling it from scratch and I do not know where and what should be mounted, .
J looking for a information or a photo of where must be montage the voltage regulator and starter solenoid switch
Re: fordson major diesel E1A electrical diagram
I suggest you look at the Ford manual to start with (https://www.fordson.se/7_El_Verkstadsmanual_191-224.pdf), and come back with anything you're not clear about. The serial number would also help as there were a few small changes in this period.
glibo
Post by glibo »
thanks for help - the manual was very helpful
serial nr: e1addn , 1136 , 1385793 -you have more manuals/photo for my major?
Looks like an early July 56, don't know where you got the two other things from. The manuals are on the old forum (http://www.fordsontractorpages.nl/ubb/F ... 01080.html), also on the FFCN. The regulator goes in the dash, I don't have any pics of that but I think there are others on the forum somewhere.
glibo
Post by glibo »
everything from the nameplate.
Do you know what rear lights should be on the fenders? like in the picture or different?
They look right. The rear lamps will also need mounting posts on the wings.
Old Hywel is right, you should get those from Agriline too if you don't already have them. There are others available too, as well as original ones on ebay and in scrapy's.
