Stuck in 1st gear
Johnm27
Stuck in 1st gear
Post by Johnm27 »
:( hello some help please moved little tractor the other day and can’t get it out 1st gear stuck fast any help would be appreciated do I have to take gear stick out!!! to free it many thanks JM
Re: Stuck in 1st gear
I think you will have to take the gear lever out, while it's out check the lever bottom is ok. Dexta's are well known for this problem. If that doesn't work please post pics and let us know if you've got a heavy load on the hydraulics.
Johnm27
Post by Johnm27 »
Thanks sandy will let you know how we get on . Thanks again JM
