Block evolution
Block evolution
The block evolution as I know it, this is quite a tricky one, especially in the early period.
The first ones were E1ADKN-6010. I don't know if the change to the oil pressure pipe connection made any change to the block but I suspect it's not the case (If it is let me know). From 1266167 the hour counter was made available by replacing the theaded plug with two 1/4" UNF tapped holes for a cover plate or hour counter, later the tachometer angle drive. Around a similar time (can't find a serial number for it nor do I know exactly what came first) dowels for the front mounting plate were added, also another bolt, I don't know if that was at the same time or not. I have no part numbers for these. From March 54 the engine was fitted in lorries and the block became 500E-6010. From 1425097 the block was altered with a larger bypass hole, new tapped holes for the new throttle, lack of drilling for throttle through the block (except petrol with governor), simpler pattern and 10 front mounting plate bolts increased to 3/8" UNC from 5/16" UNC, producing E1ADKN-6010E and the 6 cylinder engine appeared with 508E-6010. Petrol lorries were produced with 528E-6010. From around 1481091 (roughly) the block became E1ADDN-6010H, E1ADN-6010J and 528E-6010B (I don't know what changed here), and was supplied (I think) pre fitted with liners, 500E-6010B was made for service (same as E1ADN-6010J but with the earlier front main bearing cap supplied). From 1518654 locating dowels for the head gasket as always fitted to 6 cylinder engines were added. From 1591023 the liner OD was increased and an upper o-ring was fitted (a few were initially made with the new liner but without a groove for the o-ring), and 9/16" UNC main bearing bolts replaced the 1/2" ones, the block being E1ADDN-6010K, E1ADN-6010K and 528E-6010C, and 508E-6010B and 510E-6010B (500E-6010C replaced 500E-6010B). From 1613500 a new lift pump was fitted, this was made to coincide with adapting the block for the minimec although it didn't get fitted till later, a new separate sediment bowl as used on lorries was added with suitable mountings added to the block, making E1ADDN-6010M, E1ADN-6010L and 528E-6010D, and 508E-6010C and 510E-6010C (500E-6010D replaced 500E-6010C). From 08B-752791 a drilling was added to drain oil between the auxiliary shaft seal and rear bearing, although only intended for diesel engines petrol engines followed suit once stocks were used up, these were E1ADDN-6010P and 528E-6010E, and 508E-6010D and 510E-6010D. Around March 64 casting was contracted to the Sterling Metals foundry. Finally from August 64 5/8" UNC main bearing bolts and 3/8" UNC sump bolts made E1ADDN-6010T and 528E-6010F and 508E-6010E and 510E-6010E. Ebro started with E1ADDN-6010H then carried on in a similar way, but didn't make blocks able to accept all kinds of injector pump, untill late 65 they still used pneumatic governors, with no holes for the minimec, and still using the original lift pump, then changed to the minimec and omitted the holes for the previous pump bracket and used the later lift pump with no sediment bowl, all this with a block like E1ADDN-6010T. I don't really know much more, there's very poor information on this and no idea how many changes occurred.
Now for a table (missing details will be filled in as they're clarified, Ebro serial numbers are not at all clear yet so for now won't appear, Mk1 industrials (954E, 955E, 956E, 562E & 563E) are also similarly unclear as are many lorry numbers, especially ET6's):
Part no. _________________________ use
E1ADKN-6010 _________________ 1217101-mid 53
(E1ADKN-6010B)
(E1ADKN-6010C)
(E1ADKN-6010D)
500E-6010 ____________________ March 54-1425097, 500E-0001-500E-46803 & 502E-0001-502E-46803
E1ADKN-6010E ________________ 1425097-1481091, 502E-46803-approx 502E-50000, 530E-0001-approx 530E-7000 & S0001-aprox S75000
528E-6010 ____________________ 500E-46803-approx 500E-50000, 528E-0001-approx 528E-7000 & S0001-aprox S75000
508E-6010 ____________________ 508E-0001-508E-66110 & S0001-(between S221604 and S225057)
510E-6010 ____________________ 510E-0001-510E-66110 & S0001-(between S221604 and S225057)
E1ADDN-6010H ________________ 1481091-1591023, approx 502E-50000-502E-59396, approx 530E-7000-530E-23449 & aprox S75000-
_________________________________________________________________________________________________ (between S221604 and S225057)
E1ADN-6010J _________________ 1481091-1591023 & aprox S75000-(between S221604 and S225057)
528E-6010B ___________________ approx 500E-50000-500E-59396, approx 528E-7000-528E-23449 & aprox S75000-(between S221604 and S225057)
500E-6010B ___________________ Service for Mk1, as E1ADN-6010J but provided with prefitted 100 mm bore liners, replaces 500E-6010
E1ADDN-6010K ________________ 1591023-1613500, 502E-59396-approx 502E-61000, 530E-23449-approx 530E-26050
___________________________________________________________________ & (between S221604 and S225057)-(between S238903 and S242359)
E1ADN-6010K _________________ 1591023-1613500 & (between S221604 and S225057)-(between S238903 and S242359)
528E-6010C __________________ 500E-59396-approx 500E-61000, 528E-23449-approx 528E-26050 & (between S221604 and S225057)-
_________________________________________________________________________________________________ (between S238903 and S242359)
508E-6010B __________________ 508E-66110-approx 508E-76000 & (between S221604 and S225057)-(between S238903 and S242359)
510E-6010B __________________ 510E-66110-approx 510E-76000 & (between S221604 and S225057)-(between S238903 and S242359)
500E-6010C __________________ Service for Mk1, as E1ADN-6010K but provided with prefitted 100 mm bore liners, replaces 500E-6010B
E1ADDN-6010M _______________ 1613500-08B-752791, approx 502E-61000-, approx 530E-26050-approx 530EB-32000 &
___________________________________________________________________________________ (between S238903 and S242359)-approx S262626
E1ADN-6010L _________________ 1613500-August 64 (between S238903 and S242359)-approx S395000, drilling included once stocks were used up
528E-6010D ___________________ approx 500E-61000-, approx 528E-26050-approx 528EB-32000 & (between S238903 and S242359)-
_______________________________________________________________________________________________________________ approx S262626
508E-6010C ___________________ approx 508E-76000-approx 508EB-100000 & (between S238903 and S242359)-approx S262626
510E-6010C ___________________ approx 510E-76000-approx 510EB-100000 & (between S238903 and S242359)-approx S262626
500E-6010D ___________________ Service for Mk1, as E1ADN-6010L but provided with prefitted 100 mm bore liners, replaces 500E-6010C
E1ADDN-6010P ________________ 08B-752791-August 64, approx 530EB-32000-530ED-, 624EB-0001-624ED- & approx S262626-approx S395000
528E-6010E ___________________ approx 528EB-32000-528ED-, 622EB-0001-622ED- & approx S262626-approx S395000
508E-6010D ___________________ approx 508EB-100000-508ED-, 658EB-0001-658ED- & approx S262626-approx S395000
510E-6010D ___________________ approx 510EB-100000-510ED-, 660EB-0001-660ED- & approx S262626-approx S395000
E1ADDN-6010T ________________ August 64-08D-976148, 530ED-, 624ED- & approx S395000-approx S752487, Ebro made until approx S900000
_____________________________________________________________________________________________________ don't know if this was used
528E-6010F ___________________ 528ED-, 622ED- & approx S395000-approx S752487
508E-6010E ___________________ 508ED-, 658ED- & approx S395000-approx S616139
510E-6010E ___________________ 510ED-, 660ED- & approx S395000-approx S616139
And now for pics (please add any you can, lorry and industrial engines are also):
E1ADKN-6010
(E1ADKN-6010B)
(E1ADKN-6010C)
(E1ADKN-6010D)
500E-6010
E1ADKN-6010E
528E-6010
508E-6010
510E-6010
E1ADDN-6010H
E1ADN-6010J
528E-6010B
500E-6010B
E1ADDN-6010K
E1ADN-6010K
528E-6010C
508E-6010B
510E-6010B
500E-6010C
E1ADDN-6010M
E1ADN-6010L
528E-6010D
508E-6010C
510E-6010C
500E-6010D
E1ADDN-6010P
528E-6010E
508E-6010D
510E-6010D
E1ADDN-6010T
528E-6010F
508E-6010E
510E-6010E
Note the post is unfinished as I only have access to our vehicles, therefore your help with pics of the other heads is highly appreciated. I have seen some on Ebay, causing some doubts on where the part no. and EnFo (or FoMoCo) are stamped. Also Ebro parts are rather more difficult to keep track of with no proper manuals around.
Note at the time of posting I don't yet have good pics of our ones, they will come shortly.
Roadless63
Re: Block evolution
Post by Roadless63 »
Lot of info there, very informative
