Remote Control Valve Seal Kit for a Dexta.
Mervyn Spencer
Hi Folk,
Compliments of the season to you all.
Can someone direct me to a supplier of a complete set of "o" rings and gasket for my Remote Control Valve please.
Mervyn.
Mervyn.
Re: Remote Control Valve Seal Kit for a Dexta.
Hey, Mervin,
most suppliers do have the o-ring kit. you will need to order the paper gasket separately. Sometimes you can also order the plugs.
Agriline does now have a full kit also: https://agrilineproducts.com/ford-fords ... ices-50036
That kit looks ok but make sure the o-rings are the right size as if not they won't work. I wouldn't bother with the plugs but see what you think.
Mervyn Spencer
Thanks for your input Folk. I have ordered a gasket plus a knob from Histoparts and hopefully won't wait too long for them. With regards the o rings my plan is to take the remote control valve unit off and take it to a local seals and bearing supplier and see if they can help me.
Mervyn.
Mervyn.
Sounds like a good idea, remember you'll need a few wee balls to get the plugs out. (see this: viewtopic.php?p=57438#p57438)
Mervyn Spencer
Thanks Sandy for that very informative advice/information especially the diagrams. I know that I have an oil leak from the aux block but have not taken the time to establish where yet, I will be going down to the club next Saturday to remove the block. I hoping it to be the gasket, rings and hopefully not the plugs
Mervyn.
Mervyn.
The plugs are quite a common leak, we have several in need of attention, the worst is on our half Super Major and pours oil out at a ridiculous rate even just turning the PTO by hand. The others are just oosing and should hold till we fix the other hydraulic issues Super Billy and Davie have.
Mervyn Spencer
Hi, I located my oil leak out the back of the adaptor screwed into the external service unit. the adaptor was blanked off by a normal water pipe stopper so did not seal properly. Anyway I shall see if I can find the correct item to blank off the outlet. I'm going to put up another post on the aux service control valve spool rubber boot.
Mervyn.
Mervyn.
You need 1/2" BSP for that, you can either use a tapered thread or a parallel thread and copper washer.
Mervyn Spencer
Thanks Sandy, all sorted. I was able to buy a blanking stopper locally.
