Tachometer seized.
npaisnel
Tachometer seized.
Post by npaisnel »
Any one ever taken apart a tacho or any one know of common failures of them?
This one on my recent acquisition..a 1958, the input shaft is seized.
Had a little heat on it and some duck oil, and it has a little movement, maybe 1 or 2 degrees, but does not turn.
Opening it looks like an uncrimp the bezel job which I have nto got tiem to start jsut yet.
Any ideas ?
If any one finds any of my pictures of interest, please do right click and Save Them to your computer as soon as possible.
I host my pictures on my own server and since this site does not save images, they may not always be available,
npaisnel
Re: Tachometer seized.
Post by npaisnel »
Looks like I can answer my own question and will leave the results here for others..
https://forum.retro-rides.org/thread/16 ... ev-counter
https://www.britishcarforum.com/communi ... ze.109162/
I haven't yet been in one but will intend to look at Davie's one as he doesn't count hours. Henk fixed his on his Major years ago, he might have some comments to add. I would open it up then carefully free it up then test it before reassembly. Will add anything when we fix Davie's one (probably in a new thread).
npaisnel
Post by npaisnel »
Who is ‘Davie’
I thought you'd seen more of my posts, here's his story: viewtopic.php?f=3&t=8140
kiwiland dexta
Post by kiwiland dexta »
I sent mine away to be restored and was well pleased, it used to jump around and now it is all smooth plus I had them alter a new cable I bought as the ends on the new one didn't match
npaisnel
Post by npaisnel »
Looks like mine had been opened before
There were dents and bezel seemed to be split, and possiblely had been silver soldered… unless that was a factory seam.
Can see why needle moves but clock does not.
The worm gear turns but the plastic gear and hour meter drive is seized, and all teeth have been chewed off
Who did you send yours to, to be fixed ?
kiwiland dexta
I'm in NZ and used a business advertising vintage car instrument restorations. I just did an internet search.
