Fitting clutch return spring in a Fordson Dexta - Single clutch
Richard981
Post by Richard981 »
I removed the cross-shaft to fit a new oil seal. The return spring was very difficult to remove. I am expecting it to be very awkward to fit on the edge of the fork that operates the release bearing. Has anyone any advice on making this job fairly straighforward? I was minded to try and compress the spring sufficiently using 2 pieces of wire and design a tool that will apply a torque to the end of the spring to rotate it back into position.
Richard
Re: Fitting clutch return spring in a Fordson Dexta - Single clutch
I think the tool will help. Not quite sure about the bits of wire. Might be worth making the tool to fit a rachet spanner to enable extra movement. Just a thought.
Richard981
Thank you for your advice. Will tackle this job when I get the new clutch plate fitted. I have taken photos of the spring orientation before I removed it so at least I know what it should look like when correctly fitted. It was a friend who works at landroves who suggested compressing the spring slightly. I think he used tie wraps in the past and cut them when he had the release spring in place.
Richard
Richard981
Fitting the clutch return spring turned out to be straightforward. I located it on the clutch fork and this left the other end having to be rotated through about 90 degrees. I used a 9mm socket on the end of a 1/2 inch T bar. I was easily able to prise it back into position. I would advise using safety glasses for this procedure just in case the end of the spring broke.
Richard
Glad that worked, and a good caution too.
