Fordson Major E1a 1953 PTO Gaurd
GlowWorm60
Post by GlowWorm60 »
Hi Folks, does anyone know the correct bolt size that holds the PTO Guard and cap in place (3 bolts), any thoughts appreciated
Re: Fordson Major E1a 1953 PTO Gaurd
Those bolts are 7/16" UNC, 3/4" long. A run with a tap in the hole is probably worth doing, then the new bolts will fit properly. Don't forget the spring washers.
