RAL blue and orange
123Dexta
RAL blue and orange
Post by 123Dexta »
Does anyone know the RAL paint code for the blue used on a Ford Dexta? Also, I'd appreciate the code for the orange used on the wheels, if possible.
Re: RAL blue and orange
There is no such thing, the colours were specifically made for Ford. The best thing to do is to match some at a paint shop if you can. Aftermarket companies sell paints claimed to be right but it's not always true, that you'll need to check yourself or see what people say about it, we got some Agriline stuff that was good but that was over 10 years ago so don't know if it's still true.
123Dexta
Post by 123Dexta »
Thank you Sandy.
Post by Jerry Coles »
In the 1950's-60's and maybe even later, quality control on the paint colours used probably throughout the automotive industry was not so tight/high level as it is now. The paint used for tractors was lower quality than shiny showroom cars so any variation that was seen was covered by a shrug of the shoulders and a "so what difference will it make?". The colour variation will also be due to different suppliers contracted over the years. So anything remotely like "Fordson Blue" would be used in the factory. Remember that the tractors only received a single coat and it was a quick spray job. On the inner faces of my radius arms there is only red oxide as the blue never got sprayed there! So please don't get too het up over the paint colour as there were variations during the manufacturing lifespan back in those days.
I don't belive Ford did change supplier, but colours did vary throughout production. It was actually two coats, but a very quick and functional affair, with no consideration to anything like a good finish, just cover up the areas to protect from rust. Not only were areas missed, but others had runs and other features of a quick spray. The only red oxide used (the only primer used on these tractors) is on rough casting, before the machine shop, so anything other than that would only get two coats of blue (or the colour appropriate to part and period).
jan
Post by jan »
Here is an Info about the Wheelcolor for the Major and Dexta.The Volkswagen Clementine Orange is exact the same color that i find in the innerside from the wheelrim .
Colorcode Volkswagen is L 20 D
Colorcode RAL is 3070-Y70R (collection NCS )
Maby this is helpfull for someone here.
mbg Jan
Very interesting and handy. Always good to find a good match, often Brian suggested Howard orange, but that might be a bit difficult to find these days too. Colours did vary, but a good base is always better. If it matches your original colour, what more can you ask for!
jan
Post by jan »
And for the blue i Always used the Paint from CNH.Together with the Volkswagen Orange the Tractor is in a very pretty " Paintdress" .
Partnumber for 1 Liter is : 73332886
you can get the Blue only from a CNH-Dealer.
Mbg Jan
I assume you use Empire blue. Ford Tractor blue is far too dark, and isn't "green" enough. If available it's a good place as they should still have the specs. Others make these paints too but as usual there's no telling other than by checking if it'll be correct.
jan
Post by jan »
Yes,i used the Empire Blue.The Paint is very good but bot so cheap.
Very good to know it perfectly fits Ford practice.
jan
Post by jan »
Yes,it do very well.For me it was/is the best solution to give an old tractor new clothes.The tractor is a E1ADKN TVO from Sept. 1952 (1240819).My other Tractor is a County Super Six (based on a NPSM / E1A from ca 06.1964 ).The County is in the correct Colours too, all from CNH ordered.
Mbg Jan
That's good to know the NP colours are also available, we had to mix some up, but fortunately managed to get a good match very quickly. Just looked at some of your old posts, they both look great, lucky escape with the vapouriser.
jan
Post by jan »
Findung the right Blue on the CNH site can be very tricky.
Mbg Jan
