My new toy!!! E1A
Hesford
My new toy!!! E1A
Post by Hesford »
Just bought my first diesel major and has a few faults there is a milky residue in the top of the rocker box any ideas what it could be and how to fix also the gear lever twist around about a quater of a turn but can still get all gears again what could be the fault and how to fix it?
Thanks Ash
1950 E27N Petrol/TVO
1956 New Major Mark1
Re: My new toy!!! E1A
Post by Dandy Dave »
The milky residue could just be from condensation. Clean it up and see how it goes from there. If you are not loosing coolant, it will not be a problem.
The shifter housing has a hole with a pin on the side that keeps the shifter from spinning. Sometimes these push out and the the shifter spins. Get the shifter lined up the right way and then use a small punch to put the pin back into the slot milled in the shifter ball. Dandy Dave!
Hesford
Post by Hesford »
Ok thank you!
