I converted my 59 Dexta from Alternator back to generator. I was re-wiring it with a new harness and noticed it shows to ground the positive battery cable and the ground cable goes to the starter solenoid. Is this correct, this is a first for me. I thought if you grounded the positive terminal that all hell would break loose. Please advise.
Thank you,
Randy
Positive Ground Cable
justjamiefarming
Re: Positive Ground Cable
Hi TexasBlue,
You should find the information you require here:-
http://www.fordsontractorpages.nl/phpbb ... e+polarity
Regards, Jamie
Regards, Jamie
It was like that when I found it.... & I wish I had left it alone!
Texasblue
IS a Dynamo the same as a generator
Texasblue
justjamiefarming,
Thank you for your help. I will attempt that tomorrow.
Sincerely,
Randy
Sincerely,
Randy
Randy that is the way mine is wired. Positive ground and negative to the starter. I have to be careful every time I hook a meter or charger up to it.
Chris
