I'm a newby, who is looking to assist my father in law with his dexta
Two issues at present:
1. the rear hydraulic lift (he has a link box fitted at present) is unable to lift a load, (I have to shovel stuff in by hand!!!). It does stay lifted, and if you leave it overnight it seems to stay lifted. Suggestions?? Is this the pump and'or filter or other?? Any suggestions on fixing and parts I will need?
2. the rear brake shoes are becoming inneffective, I believe this is due to oil leakage from the rear axle contaminating the shoes. Any suggestions on a fix? I guess this is the rear oil seals? I've looked at the parts manual, there looks to be two sets per side? Again suggestions welcome, also any views on the parts/special tools I may need (in particular oil seals dimensions).
Finally, any suggestions on parts suppliers?? I am in Suffolk, England, but my father in law is in Donegal, Ireland?
Many thanks for the help and advice
Nigel
