foot throttle
foot throttle
hello i have been looking at my throttle on my npsm and was wondering if anyone has ever made a foot pedal for one , i cant think of a way to make it work but would really like one as i do alot of road work.
Hello Kiwi Kev,
The hand throttle keeps in place when you use the foot throttle. You need a spring somewhere to bring the throttle rod back in place. Mine is behind the fuel pump, but if your major has the rod before the engine and not through (markII) you will have to find another place.
Works perfectly. But you must not put your feet on the foot throttle, while using the hand throttle because you will think the tractor will stop when you remove your foot. But it will go on, because the hand throttle over-ride the foot.
Will take a picture of it this week and post it.
