Im nearly sure its a 1959 dexta..i get more casting numbers 2morrow..Engine no.957E7005
Chassis No.Co280098f
Dating
Raymondc71
Dating
Diesel Dexta 1960 Restyle
Raymond c 71 idont think the numbers you will identify the age of the tractor , the engine no is on a flat area approx under the number 1 injector , is punched on and not a cast number, the seirel number is on the bell housing between edge of engine adopter plate and bell housing on left side when sitting on tractor, it is also punched on . so you would have to clean it well to identify it propley. Gerry
Raymondc71
ok
i gave just these numbers to a n/h garage and tthey must have a way but i am not sure if they got it right i think she was one of the early 1960 models...sorry il get more numbers soon
These are the numbers you need to find.
Serial Number.
Engine Number.
The only number that is any use here is the K19D. All the others are just mould numbers and the same on every tractor.
Number (upside down) on the trumpet housing.
There is another down here on the side of the axle housing and one on the other side trumpet housing.
Serial Number.
Engine Number.
Raymondc71
hi
top lift 957E 7005
501B
T5
C285
Axle t3 D7F
Engine 01482139
Serial not too sure but 014823979
Near brake pedal 957E 7005
t3
d7f
501B
T5
C285
Axle t3 D7F
Engine 01482139
t3
d7f
She seems to be April 1961 by the casting codes. You still have not got the serial number though. It will start 957E then 5 numbers. The serial number is not the same as the engine No. on the Dexta, unlike the Major.
