Tractor Cab
hiking bear
Tractor Cab
Has anyone got any photos of there Dexta or know of any with a cab? At present im in the middle of building a cab but still like looking at other designs. Also does anyone know anything about cab heaters that may have been fitted into a dexta cab?
1961 Dexta, 1957 FE35 and 1966 Eicher ES101 (of which im always looking for spares).
Emil Nyman
I'll back you up with a few more angles from my fathers Super Dexta EmilEmil Nyman wrote:Here is my Super Dexta.
http://maskin.b20power.com/#5.0
There might be one or maybe two interesting images if you follow that link, this one is the same as on Emil's tractor, it's a swedish made cab, manufactured by CTO(CETO).
Dexta Cab
Nice looking cab - does it have a built in roll bar?Emil Nyman wrote:Here is my Super Dexta.
What is that on the back of your Dexta? Looks like a crane?
All the best,
That thing on the bak is a crane/winsch to pull out trees to more accessible places and lift them on the trailer. It's driven by the PTO shaft.
Seems like a quite common cab in sweden. The cab itself is the rollbar. Quite strong construction with good supports on the inside of the fenders. Here is another one (not mine) . Both my dextas had the same cab type. Sadly not the same shape.
Fordson Super Dexta, John Deere JD400 Backhoe loader
kiwiland dexta
Emil Nyman
Re: Dexta Cab
As Nisse says it is a very common cab/roll bar in Sweden. All Dextas sold in Sweden have a roll bar.Bensdexta wrote:Nice looking cab - does it have a built in roll bar?Emil Nyman wrote:Here is my Super Dexta.
All the best,
The crane is built by the swedish company "VÄSE". I bought it new two yers ago. This type of cranes is common in Sweden. The company "ROTNE" started making this wirecranes in the early 1950.
Ford 3000 -69
ÅLÖ Quicke loader
ÅLÖ snowblower
Fordson Super Dexta -64
MF Robur III -68
ÅLÖ Quicke loader
ÅLÖ snowblower
MF Robur III -68
hiking bear
Thanks for the photos. Im in the process of making mine now. It will be a cab/roll cage combined. Ive made a pattern for the frame using timber and it looks good. The steel should be with me anytime,the frame comprises of 26 sections of steel so its being cutat a local firm. Will post some photos as and when complete. I am keeping detailed drawings should other forum users be interested.
Sounds like something for the Wiki pageshiking bear wrote:Will post some photos as and when complete. I am keeping detailed drawings should other forum users be interested.
