Decompression lever
Decompression lever
Hi folks
I seem to remember reading somewhere that using the decompression lever to assist with starting the Major is bad for the engine. Could someone explain why this is please?
Many thanks,
J-P (who is off to hunt for the battery charger so he won't have to resort to this trick anyway)
Many thanks,
maybe I don't understand very well what Brian means but in my opinion,a decompressor is always a starting aid.Although I agree that it should be used whith caution and certainlly not engaged when the engine is running by itself.I have made a copy of the starting instructions whith decompressor from an instruction book for the (Ford) industrial engines but it is the same on a tractor.Note that use of decompressor is allowed either by electric starter cranking or by hand cranking.Obviously it is a two man operation unless you have a very long arm.
 [/img]
[/img]
 [/img]
[/img]If you read the text it is the same as I said but instead of using the crank, they are using the starter. It is just to allow the engine to be turned, not for starting.
A number of diesel engines use a decompressor to allow the engine to get up speed before dropping back to full compression "on a roll". Field Marshal tractors did this and so did a number of stationary engines in cement mixers and dumpers. Swing like mad and when you have momentum, drop the decompressor and the speed helps the engine over compression and she starts.
Not so with the Major. You use the crank or short bursts on the starter to enable the engine to turn over slowly. Then reset it and start the tractor. This is what the manual and the instruction books say. And so do the bent pushrods and smashed rocker gear if it is not done in this way.
