Brakes
Gman
Brakes
Post by Gman »
Hello eveyone. I have never had brakes when in reverse or going backwards down a hill, dangerous at times. Brakes work going forward, left or right works when making sharp turns. I always thought this was possibly due to the weight of the power major. Are there any adjustments that may correct this? I have never inspected brakes but sense she stops going forward thought maybe an adjustment would help.
Gerald
Gman: 1959 Power Major
GMan,
How far can you put the pedal in?
You can adjust the shoes by turning the vertical adjuster. This can be done with a screwdriver through the hole covered by a small plate behind the adjuster.
Maybe your shoes are worn too much.
Gman
Post by Gman »
Thanks Henk. I reread my post, she will stop while in reverse on level ground, she does not want to stop if on an incline or backing off of a trailer. I do not have to push pedals down very much to stop going forward. The shoes probably do need replacing, I've never looked at them. It appears the back wheels would have to be removed in order to inspect them. I will look into the adjustment and see if it helps any. Thanks for you advice, it is always appreciated.
Gerald
essex pete
Post by essex pete »
I would be interested to hear about this as well. Our old loading shovel based on a reversed skid always braked better in reverse than forward. Had rather assumed that it might be the trailing shoe effect?
super6
Post by super6 »
hi gman
i put new shoes on my major last year, i shampherd down leading edge and rear edge, i have excellent brakes going forward but in reverese i have to use all my leg power to stop her especially with my trailer on.
Maybe it is normal.
MAXPOWER
Post by MAXPOWER »
while we are on the question about brakes, anyone know a good source in the states for brake rebuild parts? i have the shoes need hardware.
thanks
Post by Dandy Dave »
I put relined shoes on my Power Major several years ago and never really thought about how it stops in reverse. I've loaded, and unloaded it off of my trailer a number of times and never had a problem. It does stop in either direction but with that said, I never try to stop it half way up the ramps either. You could set yourself up for problems doing that. I did a lot of York raking with it last year on a long driveway with a decent grade, and did not notice a problem. The brakes now need adjusting as they are starting to wear in. This will be the first time since I installed them. Next time I run it, I will take better notice. Dandy Dave!
Ian
Post by Ian »
Just buy new brake shoes. (I bought mine off ebay). You don't want to be messing too much with the old ones, since they are most likely asbestos.
Kiwi Kev
Post by Kiwi Kev »
At the risk of upsetting the purists, I have fitted a hyd master cyl to each of my brakes pedals, and a hyd slave cyl inside each brake drum. Now stops real good.
Kiwi Kev
"Classic Contracting"
International 784 4WD
& looking at another tractor!
Kim
Brakes
Post by Kim »
Hi Kev! I'd sure appreciate some of the particulars of installing hydraulic brakes on a major as I will be facing a massive amount of brakework soon and this sounds like a good way to go. Thanks! :o
Never give up!
Foxen
Post by Foxen »
With the help of a small vacuum pump driven off the crankshaft you could even get yourself some servo assisted brakes(nick off the brake force modulators from two older volvos) ;)
Kiwi Kev
Post by Kiwi Kev »
Kim
I've got the Major in the shed at the moment, already to tackle the gearbox. Will take some photos of the brakes within the next couple of days for you.
Kiwi Kev
Kiwi Kev
Post by Kiwi Kev »
Kim
Here are the pictures as promised
The master cylinder for each wheel,
and the slave cylinder inside the drum
Hope this helps you, and will not upset too many other people.
Kiwi Kev
Kim
Brakes
Post by Kim »
Thanks for the photos, I'm going to have a go at it after I raid the wreckers yard for parts! :wink:
Never give up!
Foxen
Post by Foxen »
Kiwi Kev wrote: Image
Kiwi Kev
The threaded holes facing upwards in the upper right corner on the drive shaft housing, what size thread are they?
Kiwi Kev
Post by Kiwi Kev »
Foxen
The threaded holes are 5/8 UNC.
Kiwi Kev
Foxen
Post by Foxen »
Thank you :)
Then I will be hunting for four 5/8 unc bolts very soon then
fergusont20
Post by fergusont20 »
Kiwi Kev wrote:Kim
Kiwi Kev
what a fantastic idea! looks really well done! do you have any pictures of the brake pedal setup and also inside the drums? i wouldnt mind replicating this on my major. did you have much trouble getting it all to work??
thanks Mark
