								Scruff
		Posts:  27 Joined:  Sat Jun 26, 2010 6:10 pm
						Post
								by Scruff  Mon Jul 12, 2010 6:54 pm
			Hi, I've just looked at your photos and in one of them (with the liners not quite in fully) I can see the injector pipes wrapped around something as they come out of the pump.
									May all your dreams be blue !
		Posts:  5216 Joined:  Wed Apr 16, 2008 2:07 pmLocation:  Norfolk, England.
						Post
								by Brian  Mon Jul 12, 2010 10:56 pm
			The engine is a truck engine and that is an anti-vibration device to prevent breaking injection pipes at the higher truck revs.
								Scruff
						Post
								by Scruff  Tue Jul 13, 2010 7:30 am
			Ah, ok Brian thanks.
								Nick
		Posts:  712 Joined:  Thu Jun 03, 2010 8:52 amLocation:  Somerset UK
						Post
								by Nick  Tue Jul 13, 2010 8:03 am
			ah. now ive always wondered what that was. it doesnt seem to rev that much, but what did the trucks rev to?
						Post
								by Brian  Tue Jul 13, 2010 8:16 am
			Does not sound a lot when you write it down but the original Majors were set at 1900 rpm no load speed. The truck engine went up to around 2100 rpm.
								Scruff
						Post
								by Scruff  Tue Jul 13, 2010 10:01 am
			That explains why my Super doesn't want to go very high. It has the Minimec pump and goes to about 1800-1900. Is that about right then?
								Nick
						Post
								by Nick  Tue Jul 13, 2010 10:17 pm
			so i assume, that if it revs higher, it will go faster? what did they do originally, was it 14mph?
						Post
								by Brian  Wed Jul 14, 2010 7:03 am
			Your Super is spot on at that.
								Scruff
						Post
								by Scruff  Wed Jul 14, 2010 8:39 am
			Thanks Brian.
								Nick
						Post
								by Nick  Fri Jul 16, 2010 9:05 pm
			well, got the con rod nuts torqued up, and i had forgotten how much of a b*****d the sump was to get back on, ended up with a jack under one end and a ratchet strap round the block and under the other end! Then realised, crap, i had forgotten the gasket, so back down it came about two inches, then back up again! Another stressful evening, with plenty of cider to help me along
								Scruff
						Post
								by Scruff  Fri Jul 16, 2010 10:14 pm
			I find cider helps aswell!
Scruff.
