My -55 Major fuel lift pump is leaking diesel somewhere in the priming lever area. I think it comes from where the lever axle goes through the body of the pump. So far I haven't noticed any fuel in the engine oil.
My question is would a fuel pump repair kit work in this case or do I need to get a new pump? I know that a new pump wouldn't cost that much but it would be nice to retain the original part.
Timo
						Fuel lift pump leak
I'll probably buy the repair kit then. I was just wondering if some parts could be worn too much in which case the gasket kit wouldn't help.
Thanks for the tip. I'm not entirely sure what you meant by twisting the diaphragm 90 degrees but it'll probably become clear when I have the parts in front of me.
Timo
Timo
I think that the only worn parts not included in the repair kit
is the receiver for the diaphram bar and two springs. The diaphram has a slotted bar attached and this needs to be inserted into the bit that sits on the cam in the engine and twisted 90 degrees. The diaphram has a tab that should be alligned
and pushed in on left side then twisted right until it is engaged.
Sometimes the receiver is a bit worn out with a big hole at which point you need a new pump. The springs are fairly simple to
make-up to replace.
Dominic
make-up to replace.
Dominic
