Rocker Cover
Rocker Cover
One of the bits which the bolt of the rocker cover screws into is broken off on my tractor is it hard to get a new one or what do i do ?
						Nice problem.
I had the same problem some years ago. Found a nut to the bolt, grinded a little on the rocker shaft support and welded the nut onto the rocker shaft support. It did work, but it is not what I call sophisticated engineering.
