Where does the stop cable cut the diseal supply to the engine. Does anyone have any photos of where the stop cable cuts the fuel supply in their dexta?? Cheers
Donegal Dexta
						Stop Cable
				Donegal Dexta
				Donegal Dexta
Stop Cable
Does anyone have a photo of how the stop cable is connected to the control rack on the pump??
Donegal Dexta
						Donegal Dexta
I don't have a close up picture of mine but the lever is around behind the pump between the engine block and the pump. I think the picture above is of a later model tractor with a mechanical govenor. Mine has a pneumatic govenor.
If yours is an early tractor put your hand behind the pump you will find the lever and there will also be a bracket for the cable towards the rear. To be honest the cable is in a dog of a place to connect.
				Donegal Dexta
Stop Cable
Cheers quys, if anyone has a close up of the stop cable connection at the back of the pump it would be aqppreciated. Thanks.
Donegal Dexta
						Donegal Dexta
you can see the stop control clearly in one of the photos
http://cgi.ebay.co.uk/FORDSON-DEXTA-FUE ... uipment_RL
Re: Stop Cable
I have a Fordson Power Major tractor and need to replace stop cable.  Available parts seem to come in 2.2 & 1.5 metres.  I only require 1 metre length.  Is it as simple as just cutting and reducing the lead to length required?
						Re: Stop Cable
yes
[/img]
