As I wrote in my last post, my hydraulic for the front loader seems to be some what slow. And it starts to drop to the ground right after I have it raised.
It wil drop half way down in about 10 minutes, but from there it takes about an hour to hit the ground.
I must raise the main control lever all the way back/up to make it respond, and the point where it should stay upraised seems to change as the oil heats up.
It also has a delay from when the front loader is in the ground, I pull the main control lever all the way back and it takes about 5-10 secound before it starts to raise
What could be the cause of this? And can the hydraulic be serviced to make it function like new again?
I also wonder if this could be a problem if the oil level is low?
I havent checked the oil level yet, but I suspect that its time for a change/top up.
It ain't pretty, but it will be next summer:
