I went to use my Super Dexta the other day and reversed out of the shed, when I tried to select 1st gear the lever jammed and I'm stuck in reverse.. I have read a few posts on this forum about this problem and it seems easy enough to fix but I need to know if this is a problem that Dextas have from time to time or is it soley due to worn parts. I have been told it's "just a Dexta thing." I will be fitting a new gear lever when I pull it apart.
I have also been told that the " H " pattern is very definate and they will pop out easy if gears are not positively selected. Have any other members here had this Jamming problem or am I getting false information. I would appreciate your comments on this one
as I believe it's just wear and tear..
Regards to all
Gear lever jammed in Reverse.
Stuck in Gear
I have two Dextas running and a parts tractor. A 1/2" box end wrench is always on board.
Wipe or blow dust and trash off shifter area.
Center the Hi-Low to neutral. Remove 4 screws on gear shifter and remove shifter. Wipe back area around gasket. Use wrench to center shifter collars on tranny. ReInstall shifter. Tighten and use in square H pattern until next slip up.
I have built up the end of the shifter and then filed it till it started shifting again. It will get you another year or two or decade in use.
Ultimately, the shaft bearings are wearing which cause this, and eventually the jamming problem will result in gear teeth walking and stripping.
The fix is replace the bearings or find a replacement transmission.
One of my Dextas gave another 1500 hours after build up, but now I need repair. I have a complete GC transmission.
good luck
Wayne
good luck
Wayne
Thanks Wayne for your reply. This is exactly the response that I needed. Helpfull and informative. Is welding up the end of the gear stick then filing it to fit an alternative to fitting a new gear lever as I have a new lever to go in, but it sounds like this process involves adding to the lever beyond it's normal specs in order to take up wear. I'm not sure if I have explained myself properly here but will fitting a brand new lever have the same effect.
John..
John..
hi mate
my dexta jumps out occasionaly ... a ex ford fitter told me to just build it up with weld un file it back .. as thats what they used to do
so i'm gunna do the same
i've bin struggleing to get the spring clip /circlip of tho ? the the spring loaded collar / socket is sezed on my hi - lo lever .
good luck
good luck
michael dyer
Jammed in reverse
I too suffer from the same problem, I have found that a chainsaw spanner; the one you use to tension the chain; consists of a box spanner and a screwdriver also fits the four bolts and takes up a lot less space in the toolbox.
nedwobj,
I think most of the wear will be on the shifter so a new one should do the trick.
I couldn't understand why the feel and throw on the gear selector of our latest Dexta was different than others? Pulled the top off and found that the bottom end of the shifter had been cut off and a square headed set screw had been welded on and ground down to... sort of fit! A new knob had also been welded (not quite plumb) on the top.
Les
Les
