combustion chamber cap plug washer
kiwiland dexta
Tracked down a strange hissing sound I could hear to a gas leak past the copper washer. Have been unable to source a replacement apart from a shim with the same internal dia. What other options/ sources do you guys know of?
Last edited by kiwiland dexta on Wed Oct 27, 2010 8:42 am, edited 1 time in total.
Dunggatherer
This guy in the Netherlands sells them.
http://www.histoparts.com/content/index ... ge=webshop
If you need my assistance ordering them or something just yell.
Partnumber FD8058A
Category "motordelen".
It's called "koperen pakking,voorkamer deksel".
Translanslated: Engine parts
Copper gasket,precombustion chamber
Greetings from Holland.
Rob.
Partnumber FD8058A
Rob.
kiwiland dexta
Thank you, Rob, very interesting! The originals and parts book pictures are simple circular washers but those look like a better design, by the website I take it that they also fit an MF 35, which gives me another range of local sources to try before anything else. Thanks for your generous offer, I will let you know if I need to take you up on it.
Cheers, Derek.
Cheers, Derek.
YorkshireDextaMan
I came accross this problem when doing my rebuild, and i seem to recall it has been discused before, so others may have come accross the same problem. On my head rebuild i fitted the copper (3 hole) gaskets, and they just would not seal the combustion chamber, as it happened i still had the old copper rings ,fitted them , problem solved. My tip would be not to remove the plates in the first place. or you could try fitting two gaskets. Jim
Fordson Dexta, Barn Door Technology at it's best.
kiwiland dexta
Hi, Jim, I wouldn't have removed the cap but a leak was visible when the engine was running, it blew sooty diesel (?) out in two places, and you could hear the hiss. The washer seems to be corroded so I need to find a replacement. I'll see if I can find the old thread on this.
Cheers, Derek.
Cheers, Derek.
